Seven-Story, 164-Unit Residential Building Tops Out At 149 Kent Avenue, Williamsburg
149 Kent AvenueFebruary construction 149 Kent Avenue, photo by Tectonic
In late 2014, YIMBY revealed renderings of the planned seven-story, 164-unit mixed-use building at 149 Kent Avenue, in northern Williamsburg, located four blocks from the Bedford Avenue Station on the L train. The project has now topped out and much of the curtain wall is also installed, as seen in photos courtesy of Tectonic. The building will measure 220,996 square feet in total, 129,522 square feet of which will be residential space. That means rental units will average 790 square feet apiece. The ground floor will contain 14,588 square feet of retail space in total across three separate units. Completion is expected sometime later this year, with 20 percent of the units renting at below market-rates. Global Design Strategies is designing and L+M Development is the developer.
149 Kent Avenue, rendering from GF55
1 Comment on "Seven-Story, 164-Unit Residential Building Tops Out At 149 Kent Avenue, Williamsburg"
  1. WHERE DO I GET AND APPLICATION
