16-Story, 522-Unit Mixed-Use Building Tops Out at Domino Sugar’s 325 Kent Avenue, Williamsburg
325 Kent Avenue325 Kent Avenue, rendering by SHoP Architects
Construction has topped out on the 16-story, 522-unit mixed-use building under development at 325 Kent Avenue, located between South 3rd and 4th streets in western Williamsburg. The building’s roof stands 170 feet above street level, although the additional height from the bulkhead isn’t specified in documents. The structure measures 401,246 square feet. There will be 9,378 square feet of retail on parts of the ground and second floors. The residential units should average 712 square feet and twenty percent (105 units) will rent at below market rates through the housing lottery. The project is the first building to top out within the five-building Domino Sugar Refinery mega-development. Two Trees Management Company is the developer. SHoP Architects is the design architect and Ismael Leyva Architects is the executive architect. Completion is anticipated next year.
325 Kent Avenue
325 Kent Avenue. Photo via Two Trees Management.
Follow YIMBY’s Twitter for the latest in YIMBYnew
3 Comments on "16-Story, 522-Unit Mixed-Use Building Tops Out at Domino Sugar’s 325 Kent Avenue, Williamsburg"
  1. Five buildings on mega-development, first has topped out and next waiting for construction later.
  2. Aren’t they supposed to connect at the top?
  3. The connection will be made of steel. You can see the strips and altered concrete formwork on the top three floors in anticipation.
