Seven-Story, 27-Unit Residential Redevelopment Tops Out at 1004 Gates Avenue, Ocean Hill
1004 Gates Avenue1004 Gates Avenue. Rendering by Ellipses Design.
Construction has topped out and façade installation is underway on the seven-story, 27-unit residential redevelopment underway at 1004 Gates Avenue, in Ocean Hill. The building’s design has also slightly changed, as seen in a rendering courtesy of a tipster. The latest building permits indicate the project measures 28,708 square feet, which means its residential units should average 1,063 square feet apiece. The apartments, rentals, will boast layouts with two- to three-bedroom configurations. The Brooklyn-based Loketch Group is the developer and Williamsburg-based Ellipses Design is behind the design. Occupancy is expected in early 2017.
1004 Gates Avenue
1004 Gates Avenue. Photo by a tipster.
1 Comment on "Seven-Story, 27-Unit Residential Redevelopment Tops Out at 1004 Gates Avenue, Ocean Hill"
  1. Red square on the facade very prominent, the peak of design on seven-story. (from my appraised)
