Two Three-Story, Two-Unit Mixed-Use Buildings Coming to 1228 Prospect Avenue, Longwood
1228 Prospect AvenueVacant 1228 Prospect Avenue
Bronx-based property owner Joseph Zeolla has filed applications for two three-story, two-unit mixed-use buildings at 1228-1230 Prospect Avenue, in the West Bronx’s Longwood section. The southern building will measure 2,812 square feet, while the northern one will measure a slightly larger 3,026 square feet. Both will contain ground-floor retail space, measuring 1,372 square feet and 1,418 square feet, respectively, with the residential units located above. Across the entire project, the full-floor units should average 760 square feet apiece, indicative of rental apartments. Kenneth H. Koons’s Bronx-based architectural firm is the architect of record. The 46-foot-wide, 2,903-square-foot plot is currently vacant. The Intervale Avenue stop on the 2 and 5 trains is located four blocks away.
2 Comments on "Two Three-Story, Two-Unit Mixed-Use Buildings Coming to 1228 Prospect Avenue, Longwood"
  1. At all of distance between an each spot, included contains measure on completely space.
  2. Wonder why each unit is not equivalent to retail space below?
