17-Story, 397-Unit Mixed-Use Building Rises to Fourth Floor at 515 Marin Boulevard, Jersey City
515 Marin Boulevard515 Marin Boulevard. Photo by JC_Heights via the YIMBY Forums.
Construction is underway on the fourth floor of the 17-story, 397-unit mixed-use building being developed at 515 Marin Boulevard, located between Eighth and Ninth streets in the Hamilton Park section of Jersey City. The construction update is possible thanks to a photo posted to the Forums. Dubbed Marin Residences, it will also feature 20,000 square feet of ground-floor retail space. Residential units will be located above, of which 20 percent (80 units) will be designated as affordable. It’s unclear if the apartments will be rentals or condominiums. A 261-car parking garage is also being built, in addition to a 30,000-square-foot public park directly behind the project. Kushner Real Estate Group and Claremont Properties are the developers. HWKN Architects is behind the design and completion is expected in late 2017.
515 Marin Boulevard
515 Marin Boulevard. Rendering via Hollwich Kushner.
2 Comments on "17-Story, 397-Unit Mixed-Use Building Rises to Fourth Floor at 515 Marin Boulevard, Jersey City"
  1. Termites bite the building has a rough texture, or the theme of a design therefor.
  2. Lot of construction on marin Boulevard , right near the Liberty Harbor Marina as well
