Permits have been filed to expand a two-story, two-residence structure into a seven-story residential building at 2073 Ryer Avenue in Tremont, The Bronx. Located between East Burnside Avenue and East 180th Street, the lot is two blocks from the 182-183 Streets subway station, serviced by the B and D trains. Aleksander Mici is listed as the owner behind the applications.
The proposed 60-foot-tall development will yield 13,116 square feet designated for residential space. The building will have 23 residences, most likely rentals based on the average unit scope of 570 square feet. The masonry-based structure will also have a basement and a 30-foot-long rear yard.
Node Architecture Engineering Consulting is listed as the architect of record.
Demolition permits will likely not be needed as the project consists of an expansion. An estimated completion date has not been announced.
You reported on 2077 Ryer Avenue next door in April. Are you sure all these lots aren’t part of the same new project? The details of this address sound pretty bizarre… I’d be amazed if they were actually turning a two story SFH into seven stories.
