Housing Lottery Launches for 2333 Beaumont Avenue in Belmont, The Bronx
2333 Beaumont Avenue in Belmont, The Bronx via NYC Housing Connect
The affordable housing lottery has launched for 2333 Beaumont Avenue, a four-story residential building in Belmont, The Bronx. Designed by Basic Groups Corp. and developed by Klosed Properties, the structure yields 12 residences. Available on NYC Housing Connect are four units for residents at 130 percent of the area median income (AMI), ranging in eligible income from $59,143 to $138,840.
Residences come equipped with air conditioning and name-brand kitchen appliances, countertops, and finishes. Tenants are responsible for electricity, which includes stove, heat, and hot water.
At 130 percent of the AMI, there are four studios with a monthly rent of $1,725 for incomes ranging from $59,143 to $138,840.
Prospective renters must meet income and household size requirements to apply for these apartments. Applications must be postmarked or submitted online no later than August 17, 2022.
3 Comments on "Housing Lottery Launches for 2333 Beaumont Avenue in Belmont, The Bronx"
  1. already the bricks on this building are bleaching white lines and it was just built.
    cheap pice of garbage
    Also stop calling this affordable housing!
    This is income linked housing and only affordable to upper middle income and upper income people.
    this is a joke
    • Those are lime stains knucklehead and will wear off with time or a pressure wash. I’ll ask again, do you know anything about construction?
      • knucklehead Yimby NFA its easy to try and denigrate people behind your keyboard isn’t it ? Does it give you a sense of power that you’re lacking in your real life? Are you that insecure in your own life and does hiding behind your keyboard make up for that insecurity?
        I don’t need to know anything about construction to know there shouldn’t be lime stains on any newly constructed building!! Who the fk would move into a new building that has lime stains dripping from and staining the brick?
        Would you knucklehead Yimby NFA?
        Do you see any new Stern buildings with lime dripping from the bricks?
        This is a piece of crap building!
        this is a joke
