Queens-based property owner Idan Cohen has filed applications for a four-story, seven-unit residential building at 846 Quincy Street, in eastern Bedford-Stuyvesant, located two blocks from the Gates Avenue stop on the J and Z trains. The structure will measure 5,000 square feet and there will be two apartments per floor on the ground through third levels. The project’s residential unit on the fourth floor will feature additional space in a fifth-floor penthouse. The residential space listed on permits is misleading, with only 3,000 square feet allotted for the seven units, which would work out to an average size of about 429 square feet. Still, apartments here will probably be rentals. Woody Chen’s Infocus Design & Planning is the architect of record, and the 25-foot-wide lot has been long vacant.
