Property owner Jian Le Huang has filed applications for a four-story, seven-unit residential building at 1821 Grove Street, in Ridgewood, located four blocks from the Seneca Avenue stop on the M train. The structure will measure 5,000 square feet, which means its residential units should average 704 square feet apiece, indicative of rental apartments. There will be two apartments per floor on the ground through third floors, followed by a single unit on the fourth floor. A laundry room will be located in the building. Queens-based Julien Flander is the applicant of record. The 25-foot-wide site is currently occupied by a two-story townhouse. Demolition permits were filed in January.
Pane of wood and window also curtain, invite me to survey inside.
