Four-Story, Seven-Unit Residential Project Planned at 11 Conselyea Street, Williamsburg
11 Conselyea StreetPre-demolition 11 Conselyea Street. Credit: Christopher Bride for PropertyShark
Property owner Patrick Moses is following up on applications originally filed in 2013 for a four-story, seven-unit residential building at 11 Conselyea Street, in northern Williamsburg, located two blocks from either the Metropolitan Av. or Lorimer St. stops on the G or L trains, respectively. The new structure will measure 6,499 square feet, and its residential units should average 714 square feet apiece, indicative of rental apartments. Both apartments on the fourth floor will also feature space – bedrooms, specifically – on the building’s upper penthouse level. Astoria-based Christopher V. Papa is the architect of record. Demolition permits were filed in 2015 to raze the site’s existing three-story townhouse.
1 Comment on "Four-Story, Seven-Unit Residential Project Planned at 11 Conselyea Street, Williamsburg"
  1. For me an apartment is just a means of getting from block to block.
