The affordable housing lottery has launched for 1303 Hoe Avenue, a five-story residential building in Longwood, The Bronx. Designed by Node Engineering & Consulting and developed by Luce Popaj under the 773 Grote LLC, the structure yields 37 residences. Available on NYC Housing Connect are 11 units for residents at 70 to 100 percent of the area median income (AMI), ranging in eligible income from $59,280 to $135,700.
Residences are equipped with air conditioning, charging outlets with USB ports, split-unit heating and cooling, hardwood floors, intercoms, and name-brand kitchen appliances, countertops, and finishes. Amenities include an elevator and a rooftop terrace. Tenants are responsible for electricity including stove, heat, and hot water.
At 70 percent of the AMI, there are three studios with a monthly rent of $1,494 for incomes ranging from $59,280 to $94,990; three one-bedrooms with a monthly rent of $1,548 for incomes ranging from $63,498 to $106,890; and four two-bedrooms with a monthly rent of $1,764 for incomes ranging from $76,149 to $128,240.
At 100 percent of the AMI, there is one studio with a monthly rent of $2,264 for incomes ranging from $84,892 to $135,700.
Prospective renters must meet income and household size requirements to apply for these apartments. Applications must be postmarked or submitted online no later than November 27, 2026.
Possible name: Hoe House
Tally Hoe
These renderings are ridiculous. The reality is very different, and actually worse. If this is for marketing purposes, prospective tenants will be let down when they arrive.
At least it isn’t set back from the sidewalk like the illustration suggests.
Still EIFS unfortunately.
The building goes up to the lot lines with no verdant lawn as mentioned. There are no side wall windows.
Barf.
real
