Starting off our Turkey Week rundown of high-profiled stalled construction projects in New York City is Seaport Residences, the notorious leaning 60-story residential skyscraper at 161 Maiden Lane in Manhattan’s Financial District. Designed by Hill West Architects and developed by Fortis Property Group, the 670-foot-tall tower was planned to span 200,000 square feet and yield 80 condominium units. The property, originally dubbed One Seaport, occupies a narrow rectangular lot bounded by South Street and Maiden Lane, directly across from FDR Drive and the East River.
No changes have occurred to the reinforced concrete skeleton since our last update a year ago, and the project remains in limbo since work halted in 2019 following the revelation of the tower’s 3-inch lean to the north.
Problems with the project began in 2017, when the Department of Buildings issued ten code violations against the building’s original general contractor Pizzarotti. Later that year, a worker suffered a fatal fall from the tower, and in 2018 crews accidentally poured concrete onto the street from the 34th story, leading to another halt in work.
The issue of the lean first came to light in 2019 during a public spat between Fortis and Pizzarotti after the contractor’s dismissal. Pizzarotti alleged that Fortis forwent recommendations to utilize bedrock-anchored steel supports for the foundations, choosing instead to use the less-expensive practice of “soil improvement.” Fortis claimed that this foundation shoring method was sound, and that Pizzarotti was at fault for pouring the slab incorrectly.
Despite the tumult, the structure was deemed safe and work resumed briefly under the leadership of a new general contractor, Ray Builders. However, our construction update in September 2020 revealed that sections of the glass curtain wall had been removed, and no progress has occurred on the exterior since then.
Following the partial collapse of the Pfizer Building this past July, YIMBY opined that the city should intervene to prevent a potential catastrophe. No public records exist of further studies on the building’s structural condition since the initial 2019 survey, and images from a 2024 Reddit post seem to indicate that the lean has worsened to the point of being visually apparent. However, the Midtown incident has elicited no apparent response from the city or Fortis to resolve Seaport Residences’ potentially precarious predicament.
Fortis Property Group originally acquired the property for $64 million and was anticipating a condominium sellout of $272 million. Homes were expected to start at $1.325 million when sales launched in spring 2016, just as the project began construction.
Hopefully, the public concern over the recent collapse in Brooklyn will lead to increased scrutiny of building stability. I have my doubts that jacking up the slumped sections of Pfizer will resolve the issue. The original structure is clearly overloaded by the addition, despite the column reinforcement.
If I recall correctly, the Maiden Lane lean was first noticed when the glass exterior panels were found not to fit. Some of those already installed were removed for fear of their fracturing and falling to the street.
We’re far beyond the point of absurdity for this stalled project. I sincerely hope this administration and recent events can spur some action.
Nobody will do anything because no-one wants to spend the money. So they will let it sit forever and hope it doesn’t fall.
My walk up Hell’s Kitchen tenement floors slope so much that I occasionally need to catch myself before I fall over..
The state needs to intervene and force a demolition. Hochul should be bullish on it.
Take it down. Start over. That is really the only sensible thing to do at this point.
Hats off to RAMS MSK for the tags.
